Results 1 to 10 of 15
Thread: 255-55-R19 tyers $139
    Mar 2012
    Gabbadah WA
    Found a tyer on the net called Sunitrac Focus 9000 , In 255-55-R19 with a load rating of 111 WXL , for $139 delivered to any Ultra Tune store for fitting at $15 + $ for balancing , also in 255-50-R19 for $149 .
    Anyone know anything about Sunitrac ??? , going by the name it would be a chinese brand . Not sure if they are anygood for general road work but gee whiz the price is temting to find out more .
    Al
    Aug 2010
    Generally you get what you pay for.
    I would not put such cheap tyres on either a D3, D4 or RRS.
    We dont mind if you are the Guinea pig!
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    South Sydney
    So you want to put $139 tyres on an ~$80,000 2.7tonne Land Yaught??? Would make for some fantastic understeer in the wet i would think.
    Each to their own, just don't drive anywhere near me.
    Mar 2012
    Gabbadah WA
    Quote Originally Posted by ~Rich~ View Post
    Not sure i would use them unless some one with the correct knowledge on tryres recomended them , but may be of use for a spare or trailer etc .
    Apr 2012
    Coolum
    I cannot speak from experiance ..
    But
    I would like to add, there are a lot of cheaper options available these days .. I am looking at getting a 285 60 R18 for sand (which I hope will give me a bigger footprint and slightly more floatation) and general road use.
    I do not drive like fangio ( I have a sports car for those days) and I dont drive like a dick in the wet.
    So if you have a brain and you drive according to the conditions, and you dont intend crossing the simpson on them, I don't (IMHO) believe you'll really get to see too much diff between the cheaper brands and the real raver reviewed tyres.
    If you hit the gravel you'll probably also find they are lacking ...!
    Sure you may be back in the market sooner (tyre wear) but then you can make a choice sooner (again).
    These tyres have the same load, speed and safety codes (at minimum - 'up to spec') so much of the 'quality' work has been done for you by the 'authorities' Unless I'm mistaken. If I am mistaken - it wouldn't be the first time.
    Although - a 2 + ton missile is controlled largely by the 4 little bits of rubber in contact with the ground is possibly the focal point for all sorts of 'situations' many unknown and some of the unknowns of crisis level, it may be the case that the right choice is more important then one would think.
    but then again, if not for some, taking a risk to investigate, the world would still be flat.
    enjoy your choices.
    Sep 2010
    melton, vic
    Stay away from them thats for sure........
    Aug 2008
    Sunshinecoast QLD
    Quote Originally Posted by boofdtl View Post
    WHY
    Dec 2010
    Parkdale, Melbourne
    Taiwanese ditch finders (TDF's) we used to call them, back in the day of cheap Jap car imports in the UK. Every damned one of them was fitted with these granite compound no name tyres that offered bugger all grip and didn't wear out. First trip out usually ended up in a ditch, hence the nickname !!
    They're great for airfield track days though, learning about car control and that's as far as I'd use them anymore. Would I put them on my $40k RRS ? No chance.
    Quote Originally Posted by Mike_S View Post
    Exactly.....
    Cheap is cheap... I will never, ever skimp on Tyres or Brakes... Ever!
    Jan 2010
    Edmonton Alberta Canada
    If they were repriced?
    Quote Originally Posted by Fatso View Post
    Found a tyre on the net called Sunitrac Focus 9000 , In 255-55-R19 with a load rating of 111 WXL , for $139 delivered to any Ultra Tune store for fitting at $15 + $ for balancing , also in 255-50-R19 for $149 . Al
    What bothers me most is that if the tyres were priced at a somewhat higher price point, would they then be considered "good value".
    If there are no tyre reviews of them around, I would wonder why. I did Google the Sunitrac brand and the tyres seems to be for sale worldwide, but again, no tyre reviews found.
    These tyres probably have the same quality control standards as do the XYG windscreens, if you build it, ship it.
    The marketplace will eventually sort it out so the question is merely do you wish to be a paying member of the sorting group.
