It is expensive but not that expensive.
 Fossicker
						Fossicker
						Hi
was quoted around $2000 for a double flush by garage on a 2005 Disco 3 with about 80,000 - guy seemed to know his stuff. Is this a reasonable amount to pay?
Thanks in advance
 Fossicker
						Fossicker
						thanks Garry, what is a reasonable price in your opinion?
It sounds way expensive, I'll ask a private LR workshop I go to in the inner west how much for a double flush and a steel pan instead of the throw away plastic pan and let you know.
cheers,
Terry
Terry
D1 V8 (Gone)D2a HSE V8 (Gone)D3 HSE TDV6 (Unfortunately Gone)D4 V8
Give Graham Cooper Automotive a ring , on 0245779584
 Fossicker
						Fossicker
						thanks - i tried getting hold of Ward at GC but he's flat out. any advice would be greatly appreciated.
Got mine done in Perth full flush + steel pan and filter $1200 . dont let them tell you the trans lifegaurd fluid is $70-80 a ltr , you can get the fluid fron ZF transmitions themselves for $35 ltr , takes about 12/13 ltrs for full flush . Al
With 80,000ks I would just order a drum of oil from ZF and change the oil a few times.. If you have ever changed Diff oil before its the same with the gearbox. The manual tells you to check it upto a certain temp, but using hawkeye the oil temp is within spec for the first 4-5 minutes of start-up..
The choice is yours, but I changed mine at 79,000ks and the pan and filter as well, but if had my time again I would just have changed the oil only.
Just my 2c worth.
Cheers Ean
 Swaggie
						Swaggie
