Results 1 to 10 of 20
Thread: Replacement Engine & Auto box for Defender?
    VladTepes's Avatar
    Bracken Ridge, Qld
    Think "economical" and "affordable"
    I would like to change my Defender from Manual to Auto. One option would be to pop a Disco box in there instead of the R380.
    On the other hand I've had a few dramas with heh Tdi over the years and was thinking that it would also be the right time to consider other options at the same time.
    There was some info in another thread here (which I can't locate) regarding replacing teh Tdi with a Holen Jackaroo diesel of some sort. Apparently has similar power to the Tdi but parts etc should be easier to get ?
    Anyway does anyone know the one referred to? Good engine? What about the auto gearboxes that match up? Are adaptor kits available and if so do they adapt the engines to teh R380 or an engive nad gearbox to teh trans case?
    Discuss.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    in the wild New England, NSW
    Quote Originally Posted by VladTepes View Post
    Discuss.
    hey Vlad - what is not easy to get in the way of 300tdi parts? - if that is your only problem
    (I think I'd rather cope with tdi annoyances than those that I've heard of with the Jackaroo diesel)
    WA
    I assume you are talking about the isuzu 4JB1T. 2.8L 4cyl.
    There are a couple of UK companies which make adaptor kits to mate one to a ZF auto from a disco. That would be your best option - 4JB1T/D1 ZF auto/LT230, as I doubt you will find an adaptor to mate a jackaroo auto to an LT230.
    No engine conversion is cheap... And as for economy, the cost of an engine conversion will buy a lot of diesel...
    Oct 2008
    jackaroo engines have a lots of dramas
    From what i understand they use oil to pressure for fueling similar to what CAT used.
    d@rk51d3 Guest
    Quote Originally Posted by Benny_IIA View Post
    Yep, don't change fuel & oil filters at the same time.
    easier just to leave the tdi in place then drop in a disco box.
    Just so happens a dead vehicle I'm looking at aquiring for some parts has a workable auto and tcase...
    VladTepes's Avatar
    Bracken Ridge, Qld
    ENGINE
    Thanks all. Yep just wondering out loud.
    The Tdi seems to be down on power and no-one seems to be able to get to the bottom of it... (haven't had a chance to get out to see blknight yet though)
    I just figured if I was goiing the auto route it was the appropriate time to also consider these other things.
    What other engine options are there?
    (I did find this thread but there must be more)
    Engine Options...
    A little more power wouldn't go astray but I don't need a TDV8 powerhouse that'll start snapping expensive drivetrain bits
    From the sound of it chucking in a ZF from a D1 wouldn't limit my engine options too much if I wanted to look at an engine change down the track...?
    AUTO CONVERSION
    On the auto conversion - trying to work out how much it would costs / how easy or difficult it is to do. Some of the indicative quotes I've got are around $6K which seems way too expensive to me... ?
    gone
    1996 Discovery 1
    current
    welll if you got the gearbox for nearly nothing.
    the enginerring cert would be ummm $500 by the time you did everything.
    the welding of and panel shaping to make it fit would be the hard bit.
    Australia
    redrovertdi Guest
    I put a disco auto[and later a transfer case] in my 300tdi defender a little over a year ago, best thing i ever did. there was no welding or panel shaping required- just covering the r380 gear lever hole and drilling a hole for the auto selector cable, Vlad you welcome to take it for a drive to see if you like it.
