                                                27th September 2012, 09:15 AM
			defender transfercase larger sump
					hi all firstly thanks for the help on finding the rattle in my defender it turned out to be the speedo drive cable i must have loosened it through the gromet made it rattle in the dash.
 does anyone know where i can get the extended sump for the lt230 transfer case it increases the transfer case oil capasity by a litre and ahalf allso has a provision for a temp gauge i think roverdrive do them in the uk but dont know here thanks in advance
                                                27th September 2012, 09:25 AM
                                                27th September 2012, 09:41 AM
					I got mine from these guys
 British Off Road - The Land Rover spare parts specialists - Home
 It is made by Roamerdrive (formerly Roverdrive)
 IIRC the capacity is increased by 0.7 of a litre.
 Paul.
 Paul.  77 series3 (sold)
95 300Tdi Ute (sold) 77 series3 (sold)
95 300Tdi Ute (sold) 2003 XTREME Td5 2003 XTREME Td5
 I thought I was wrong once, but I was mistaken.
                                                27th September 2012, 09:49 AM
                                                #4
					Regarding provision for a temperature sensor, the position for this is on the upper left side of the LT230 case. From memory it is toward the rear and in a wide horizontal rib.
 In LT230's that don't have the sensor fitted there is a hexagon head plug in the hole where the sensor goes.
                                                27th September 2012, 06:41 PM
                                                #5
					I got mine from these guys. Freight was quite cheap and was delivered in a few days. To place the temp sensor in this sump requires drilling and tapping but the recess is cast into the sump.
 Rocky Mountain Spares UK > Improved Engineered Parts and Accessories for your Land Rover
