Hi,
I swapped my rear puma diff housing for the disco one. Just remember that the spring perches are about 1/2" further apart on the Defender housing.
Cheers, Tristan
 Fossicker
						Fossicker
						i have a series 1 disco with fully loaded ashroft goodies.
i am planning to buy a 2012 defender in december and would like to know if i can simply swap the entire axles with my disco?
i don't se why it woulden't as the suspension seems exactly the same and everything else is interchangeable.
Please help techno rat's
Hi,
Cheers, Tristan
I hope it does, I've just bought a donor Disco1 to put the running gear under a County chassis. I understand the Disco rear axle has a lighter load rating than the Salisbury and P38 type Defender rear axle.
Slunnie
Simon, you'll just have to change the rear spring perches, otherwise it should bolt up ?
I forgot, the discs and callipers are different on the Disco front and back too.
IIRC the Defender uses larger bore pistons in the calipers and the discs are vented on the front (the vented discs only applies from I think the 200Tdi on)
 Fossicker
						Fossicker
this is what i wanted to hear very happy vegiemite
