                                                28th September 2012, 09:36 AM
			Radio on when opening door
					Here is a quirky one.
 My radio comes on AM band when the door is opened for a period of five seconds then turns off.  if i power the radio up it resumes as normal on aux line in.  it also came on for five seconds after i closed the door...
 no other warnings or alarms.
 any sugestions?
 Will
 Disco 4 sdv6se
                                                28th September 2012, 01:38 PM
					Glitch, back to dealer. I am having issues with my ICE as well.
                                                28th September 2012, 03:55 PM
					might just be a coincidence BUT
 i had my electric brake controller tuned down to zero.  i since turned it back up a little and havent had the radio problem since....
 it has only been half a day though....
                                                28th September 2012, 04:00 PM
                                                #4
					Weaird.
 There is abit on the wiring of them on here but very odd if it affected the ICE.
 Maybe it wakes the D4?
                                                1st October 2012, 11:38 AM
                                                #5
					Mine had a loose and arching Neg Terminal on the chassis side....took forever to find the issue but it finally loosened off enough to be found when my battery wasn't charging properly and LR were investigating.
 As well as not charging the battery properly it caused all sorts of issues....static noise, bad gear changes, windows opening when doors or other windows were opened or park brake applied....it was driving me nuts.
 LR replaced the lead and it's been flawless since.
 These cars do not like stray voltage.
 Kev.
                                                10th October 2012, 03:24 PM
                                                #6
					so for a update.....
 still havent had the radio great me again since i turned the electric brake controller up.
 Personality???....
