                                                28th September 2012, 10:35 AM
			 defender 2002 which pads/wheel bearings? defender 2002 which pads/wheel bearings?
					Any brands anyone would suggest for brake pads on 2002 Defender?Not sure what's good/which one's squeal...also after wheel bearings-so far looking at Timken as a brand...and while I'm here have to do coolant change.Am looking at an organic coolant(as per manual)...any suggestions?
                                                28th September 2012, 11:24 AM
					I am just about to do the same job on my 1999 Defender,am going to use Delphi/Lockheed pads,new rotors from Roverparts...free postage if you put code as aulro.You may also want to consider converting back to the dual locking nuts as per this ebay site eBay Australia: Buy new & used fashion, electronics & home d Also if you go oil filled use RTC 3511 seals.
