HMMM i put it on mate and works fine, what version of reader do you have installed, i have 9
Has anyone got RAVE working with Windows 7?
Everytime I try to run it, it starts the RAVE version of Acrobat, opens the Welcome.pdf file and then fails with this error message
works fine here - I'm slack V 4.0 of adobe reader.
I'm trying to run it from the disc with the supplied special version 4. A "genuine" copy won't run with a normal version of Acrobat.
I wonder if Acrobat Professional V9 is interacting with it. I might uninstall it. It was never a problem under XP.
Not having any problems running it under Win7x64 and Acrobat pro v9 installed.
Also run it on the netbook with win7 starter. (no acrobat though)
Martyn
1998 Defender
2008 Madigan
2010 Cape York
2012 Beadell, Bombs and other Blasts
2014 Centreing the Simpson
VKS-737 mob 7669
Ahhh Ron i copied the contents into a fold on c: (Landrover) then ran from there, works fine, could be worth a try![]()
I've deleted both Acrobat Reader and Professional. Still fails.
Copied to C: drive. Still fails.
Tried a different version of RAVE, still fails.
Something has got to be conflicting ??? but the thing is what, have you tried right clicking on the rave exe and run as administrator
How did you go Ron
