Results 1 to 10 of 12
Thread: Stromberg Carbs
    Mar 2009
    Near Geelong, Vic.
    Stromberg Carbs
    I have a non starter UNLESS I prime it with petrol down the carby.
    Looking down the throat and working the throttle, I see no evidence of an accelerator pump. Surely they have one?? Should I see a squirt of petrol each time I work the throttle?
    Can someone give me a link to how Strombergs work?
    Aug 2010
    Sunbury, VIC
    They do have an accelerator pump. If you are operating the throttle and not seeing any fuel squirting out, then you will probably need to stuff a kit through the carby - very easy to do on these. The accelerator pump bucket washer will be worn and passing fuel behind it.
    Here's a pic of one pulled apart clearly showing the accelerator pump chamber.
    This kit - STROMBERG CARBURETTOR GASKET REBUILD KIT HOLDEN EH-HD-HR-HK-HT-HG-HQ SMALL BASE | eBay and a couple of hours should see it all fixed.
    Cheers - Gav
    Aug 2012
    Adelaide
    Goedon,
    I'm having similar troubles. Have to give her a sniff when she's cold or wont start. Once it's hot/warm no problems at all! I've put a new carbi kit through it too.
    Irymple, Victoria, Australia
    A couple of drops of light oil down the plunger hole might get your accelerator pump working if it has a leather bucket on it (some are leather and later kits have nylon).
    Strombergs are a pretty good simple and easy carb to work on.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by debruiser View Post
    Goedon,
    If you have put a kit through it and still have issues when cold, check to ensure the choke is fully closing. These engines need quite a rich mixture to start when cold.
    Aug 2012
    Adelaide
    Quote Originally Posted by bacicat2000 View Post
    ahhh... I had sort of suspected this! Thank you for confirming it! I am going to have another play with the setup for the choke.... Got it to start today without a sniff! yay!
    Aug 2010
    Sunbury, VIC
    I remember as a child watching my old man trying to start the Kingswood on a cold morning - even when it was new, he used to have to pump the throttle heaps and almost rip the choke cable out of the dash to make it go - mind you, that was on a frosty morning when the whole car was white and you almost needed a chisel to get the ice off, but you get the idea.
    Although not impossible, it is quite hard to flood these when they are cold, don't hold back on pumping the throttle.
    Cheers - Gav
    Aug 2012
    Adelaide
    I'm not sure but I could swear that the old girl is starting to get easier to start! maybe i'm just getting used to how to do it.....
    I just start it more like I used to start my old Ford Laser, heaps of throtle!! haha.
    Thanks for the help guys.
    Mar 2009
    Near Geelong, Vic.
    Don't underestimate the effectiveness of accelerator pumps to prime the carbs for cold starts.
    Very early Porsche 356's had twin Solexes but NO chokes. The factory cold start recommendation was to prime them by repeatedly pumping the pedal.
    That was a far more practical solution than Ettore Bugatti's solution for a customer who said his cars were a bitch to start when cold: "Well then Monsieur should get heating in his garage!"
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by geodon View Post
    Hello Geodon,
    Another thing to watch out for is mix-matched Stromberg carburettor parts. A previous owner of my Series III had a different base and the wrong carburettor for my 202. It had a 161 carburettor main body fitted and a different base even for the 161. This combination was then put on to the 202 motor. Bolted on to the incorrect inlet manifold as well.
    This could probably be why the former owner had some high speed issues on the highway.
    The link below is a pretty good site for checking to see that everything is as it should be on a Holden carburettor.
    http://www.scribd.com/doc/68315221/4/Stromberg-Carburettor-Model-Numbers
    Kind Regards
    Lionel
