[QUOTE=SuperMono;1770271]Last week I swapped back to road tyres from the muddies and noticed a new noise from what has otherwise been a very quiet 200K+ TDV6 'S'.
Looking for a few hints as so far I haven't been ably to clearly identify the cause.
It isn't very loud, my wife can't notice it and fitting the KM2s will mask it.
The noise is apparent from about 15kmh up but is not apparently sensitive to speed or load, no change in pitch, volume or presence.
It is not from the engine as it isn't present when stationary but is if you select neutral and kill the engine at low speed (rolling at 15-20kph).
I can best describe the noise as similar to:
1: wind noise on an old roof rack.
2: bearing loose in a housing (growl, growl)
3: turbulence or air in a fluid transfer pipe.
At first I did think it was wind related, but I'm not convinced.
I did fit one of the Green Oval radiator protection plates so might tape that over just to rule it out.
Supermono, If the tyre change has initiated the noise, I would be looking at wheels and tyres first. Swap them around, or get hold of a std set that you know are not causing any issues. Likewise anything that has changed or has been changed should be eliminated first.
  Reply With Quote D4  2.7litre
D4  2.7litre
