Hi Shining,
If you do a search on battery D3/D4, you will find a lot of posts on this issue. You have not commented on your second battery, so I assume it was ok.
My advice would be to first check the condition of your main battery, and don't assume that because it tests ok, all is good. I have found that if the main battery is the slightest down in performance, it will run flat enough to cause starting issues, very easily, and quickly.
With a battery slightly down, leaving the doors open, and the keys in the ignition will chew down the battery in less than a day. The interior lights can be turned off by holding the main switch down as per the proceedure in the owners manual. The key is better off out of the ignition in my opinion. ( others may have comment on that ) I think the computer will also use power if you are in and out of the car, as it probably won't go into sleep mode.
I have replaced pretty much all of the interior globes with LED equivalents. This drops the draw a hell of a lot. If you count up the globes inside the vehicle, I think it is about 15, and they all come on if you have the all of the doors open. Once the kids start jumping in and out, opening and closing doors etc, the lights keep resetting unless you have deactivated them as described previously.
The Traxide system links the main and aux for a period until the voltage drops to a set value ( sorry, can't recall what that is off the top of my head ) , and again if your main is a little sus anyway, that little extra taken off the main, is enough to get it into trouble. Tim will advise that the voltage left in the main by his Traxide system, is easily enough to start the vehicle. In technical terms that should be the case, but in practice, a sus battery, and lights radio or computer drawing juice, and you are in trouble.
I make sure my batteries are in good nick, and are both fully charged using a good smart charger before any long trips. I also carry a portable battery starter as insurance.
Have a good read of the other postings on this subject.
  Reply With Quote D4  2.7litre
D4  2.7litre
