 Originally Posted by
drivesafe
				Hi Malcolm and there is no problem with connecting the charger while the battery is in place.
If a problem occurs with the charge, your battery is the only thing that is likely to be damaged because your ignition will be off so nothing else is in danger of being damaged.
 Lots of the electronics (eg the suspension ecu, alternator, immobiliser) never disconnect from power, not that it would stop me from connecting a charger to the battery in-situ with the normal precautions of good cable connection practices.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
