Results 1 to 10 of 21
Thread: Every 3 years
    Cessnock NSW
    Every 3 years
    Well I have spent the past couple of days making sure all the Land Rovers are up to scratch. This year I'm having them pink slipped and they have to be spot on!.
    As usual SWMBO said why bother so early, something will go wrong before the due date, bad vibes I said, also told her to get lost LOL, well it wasn't long before what she said hit home. 'Lady' my Series2 C/R, the starter wouldn't engage, methinks Gee I hate pulling starter motors out, anyway out with the crank handle from behind the seats.
    Prime the fuel system (hopefully) engage starter handle in the crank dog, carefully pull it over until handle is at the 6<<>>7pm position and pull like crazy upwards, a small fire and stop, so I took the air horn off the carburettor and tip a small quantity of petrol down the throat, carefully pull handle around to the same position, hey it fires, no wait a minute it didn't fire it ran backwards and hit my Right hand about 4 times before I could pull it away, geez that hurt, and it still does around 24hrs later anyway it did eventually start off the crank handle and the starter motor problem turned out to be nothing more than a flat battery.
    Roll on through the day getting different Landies out of their long sleep (some haven't turned a wheel since the 25th April 2012, all seemed to be going well until I was putting them away again, the gunbuggyshh!!
    brake master cylinder decided it was time to give up working and leak all over the floor bugger I thought, anyway I had to re-arrange my 'Rubic's Cube again so I could work on it, and today I did just that.
    I used my tried and tested method of draining brake fluid from the reserviour by using a s/hand (used) syringe from work
    http://i659.photobucket.com/albums/u...9;t=1350195496
    it takes a little time but a lot less mess.
    Next out with an air hose and my 3/8" butterfly rattle gun n sockets loosen off the 6 x 5/16"UNF bolts that hold the brake pendant assembly, undo (carefully) the fittings on the side of the reserviour to M/cyl, then remove the 6 bolts lifting out (with some degree of difficulty) the brake assembly.
    Set it up in the bench vise and proceed to remove the bolts that hold it into the housing
    http://i659.photobucket.com/albums/u...9;t=1350195559
    Once it has been removed I cleaned all the crud out of the housing and put it aside for the time being. Some time ago I bought 4 CV type M/cyls from a dealer in the UK, this is the last one (note to self buy a few more). The Land Rover had a 109" CB M/cyl fitted?? anyway it is US.
    I always run the correct size tap/s into the threaded holes, as sometimes just the smallest burr can cause you a heap of trouble, 3/8"UNF first
    http://i659.photobucket.com/albums/u...9;t=1350195734
    always hold the cylinder upside down, so if there is any debris it will succumb to gravity, next the 7/16"UNF
    http://i659.photobucket.com/albums/u...9;t=1350195787
    A quick look under the right hand wing, showed some flakey paint etc, so I scraped it off, and not having any O/Drab paint I used brushable ?? You know the stuff LOL just to protect it
    http://i659.photobucket.com/albums/u...9;t=1350195848
    While that was drying, back to the housing, by running a 5/16"UNF tap through the 6 holes, I like to be able to screw things up with my fingers
    http://i659.photobucket.com/albums/u...9;t=1350195908
    then refit the new M/cyl to the housing, the bottom bolt is always a source of delight, trying to get it into a hole that isn't straight down LOL, anyway a short length of mild wire wrapped around the bolt allowed me to position it while SWMBO put the washer n nut on
    http://i659.photobucket.com/albums/u...9;t=1350195970
    and thast about as far as I got today, as I don't have any 1/4"OD bundy tubing, it will have to wait until later in the week when I can get hold of some, anyway cheers Dennis
    Cessnock NSW
    Meanwhile 2 days later SWMBO had been to Maitland and purchased a few lengths of 3/16" & 1/4" bundy tubing, yesterday (Tues) I double flared one end put the male fitting on it and that was about all I had time for, this afternoon I had from 1500hrs until now to do what I needed to do.
    Out with the tubing bender and made a 90 deg bend, then work out roughly where to cut the tubing off, so I could then see where to bend it again to meet up with the brake reservoir.
    This was done with a degree of difficulty as the Gunbuggy still has the wings on
    anyway this is how I measured the tubing to cut it off at the right length
    http://i659.photobucket.com/albums/u...9;t=1350455523
    you can see where I marked the tubing, cut it off, fit female union nut and double flare the end, ending up with this
    http://i659.photobucket.com/albums/u...9;t=1350455582
    that is 'Max' Digger's sleeper, he is always nosing around when I'm near the gunbuggy, anyway the new tube fitted up like the proverbial finger in a (you know)
    http://i659.photobucket.com/albums/u...9;t=1350455647
    now tomorrow just adjust (hopefully) the outlet pipe to suit the new Master cylinder, if it doesn't line up satisfactorily, I will have to remake it, anyway cheers Dennis
    Cessnock NSW
    Today is THE Day!!
    Well what a lousy start to the day, overcast, BOM forecast for showers etc, BOM radar showing small isolated patches around, anyway at 0715hrs I started to fill the street with Land Rovers.
    It took about 1 1/2hrs or so to get them all out and ready, and wouldn't you know it, Rain rain n showers, it was a mad scramble to cover some vehicles, the street looked full with all my vehicles
    http://i659.photobucket.com/albums/u...w/IMG_0700.jpg
    and on the other side of the street
    http://i659.photobucket.com/albums/u...w/IMG_0699.jpg
    yes there are 2 vehicles missing, they were kept near cover in case of heavy rain.
    http://i659.photobucket.com/albums/u...w/IMG_0701.jpg
    http://i659.photobucket.com/albums/u...w/IMG_0702.jpg
    But before this went out I stripped it of some of it's accessories
    http://i659.photobucket.com/albums/u...w/IMG_0698.jpg
    anyway it all went smoothly, only found a few minor problems, the pinch bolts on the drag links had vibrated loose, out with some spanners and in minutes it was fixed, everything else was OK, funnily enough it took over 2 hours to put it all away, only have to take the No5 to it's lodgings tomorrow, anyway cheers Dennis
    next date for this job 2015
    Cessnock NSW
    On going Maintenance (Brakes)
    Today was club registration day, I rolled up in my 110 County, a fellow club member asked ?? 'Where's The convoy??', I replied in my hand, I had them all Pink Slipped.
    After arriving home from that venue, I removed the RHS front brake drum and shoes etc on my 109 WKSP, the wheel cylinders were new items when the vehicle was being rebuilt, but with only occasional use this is how they finish up, not very nice looking at all, add to that brake problems etc etc
    http://i659.photobucket.com/albums/u...w/IMG_0942.jpg
    down in the depths of the shed I have a full front set that has been Stainless steel lined, this will be my 5th vehicle that I have done in past 11 months, only 3 to go.
    As usual 'Murphy's Law' is always applied here (dunno why!!??) I couldn't find the 3/8"UNF bolt that I had turned down to accept the flared end of the 3/16" bundy tubing, so the system doesn't backfill with AIR, so I had to remake a rough one
    http://i659.photobucket.com/albums/u...w/IMG_0941.jpg
    those of you who have been here in the past will know what a mess my shed "was in", but I have been making progress (and spending big bucks) buying all manner of items that can accommodate tools/nuts n bolts etc, I must have just misplaced it, anyway tomorrow I will clean up the backing plate again, repaint if needed, fit the refurbed wheel cylinders, then start on the left side, anyway thankfully in 3 years time I will not be revisiting the brakes, now onto the oil leaks LOL LOL LOL, cheers Dennis
    Cessnock NSW
    This afternoon after lunch I took on the job of reassembly of the R.H.S front, I would have been further along except I took pity on swmbo who had a shopping list as long as my arm (we had been away for approx 10 days) so lunch first then into it.
    A quick run over with a wire brush to remove any loose paint n dirt, spray with brake kleen, allow to dry, a quick coat of Gloss Black (White Knight (Squirts)) and your ready to reassemble.
    I have learned from past experience that when refitting the 2 wheel cylinders, to fit the top one (Leading) leave the 2 x 5/16"UNF nuts loose, then fit the interconnecting pipe to that cyl, only screw it in approx 50%, then fit the bottom cyl (Trailing) and do the same with the interconnecting pipe, after you have made the connections, and everything is screwing up easily, no crossed threads, (as I have shown in the past, I always run the appropriate tap into the wheel cyl's just to make sure no burrs etc) continue to tighten it all up.
    Brake shoes cleaned with Brake Kleen and allowed to air dry, check the drum to make sure it's clean, reassemble the shoes onto the brake anchor plate (aka brake backing plate), check that the cam adjusters are backed right off, tap shoes into position, refit the brake drum with the 3 x 3/8" csk Whitworth screws, spin the drum and check for any dragging, luckily for me the drum spins freely.
    After that I refitted the flex pipe from the brakes to the chassis, another quick squirt of gloss black over the exterior and it all looks like this
    http://i659.photobucket.com/albums/u...w/IMG_0943.jpg
    now for the LHS, but not today, I picked up somebody's bug while away, I have a headache+++, sore throat n cough, so tomorrow will be soon enough, cheers Dennis
    Cessnock NSW
    Just when you think it's safe to park up, something else calls it home
    http://i659.photobucket.com/albums/u...w/IMG_0947.jpg
    not sure what type of feathered variety it is as yet, we have Blue wrens that nest about in the trees??
    Last Thursday I jacked the rear end clear of the floor, stands under, wheels/brake assemblies off, it was certainly cleaner than the front, they were not seized, but no point in just doing half a job
    http://i659.photobucket.com/albums/u...0/IMG_0945.jpg
    I took both rear wheel cylinders to the usual brake place, have them back next Thursday when Im working in the area.
    In the meantime, I have moved forward on this little job, mounting an Isuzu alternator onto the Land Rover engine block
    http://i659.photobucket.com/albums/u...w/IMG_0949.jpg, I missed out getting a few different length A belts, I think I have the pulleys lined up, bit in my mind I think it would be easier to see any misalignment with the belts fitted, anyway no rush on this job , cheers Dennis
    ps who ordered the HEAT WAVE
    pps I have placed an order for 4 lts of Protec Cam/Green, we will see what transpires,,.
    did you want a double grove crank pully for that thing?
    Cessnock NSW
    Yes please, I don't have a spare one, cheers Dennis
    Cessnock NSW
    Got the Protec paint.
    Well, I'm no further advanced with the brakes on my 109Wksp Land Rover. The rear wheel cylinders were sent away a week last Thursday, I should have had them back by Wednesday of last week, but somehow my wheel cylinders and another customers full set for a Morrie Minor bits have gone missing.
    No fault of the brake service, the courier is at fault, gawd knows where they are??!!!.
    Meanwhile I had placed an order for this, no issues getting it!!
    http://i659.photobucket.com/albums/u...w/IMG_0962.jpg
    it arrived yesterday, this afternoon I cleaned up the 2 front wheels, brake fluid and paint doesn't mix, in fact they hate each other, the inside of the rims were pretty ordinary, so a good clean with flap sander (die grinder) and some elbow grease, a quick coat of etch prime and 1 of O/D
    http://i659.photobucket.com/albums/u...w/IMG_0963.jpg
    a little while later they both had 2 coats of O/D on them,
    http://i659.photobucket.com/albums/u...w/IMG_0964.jpg
    all we need now is the brake wheel cylinders, so I can finish this job, cheers Dennis
    Cessnock NSW
    Well after the wheel cylinders had a free weekend in Sydney ??!!somewhere the errant items returned home today to be reunited with the rear end they look a better than they did 2 weeks ago
    http://i659.photobucket.com/albums/u...w/IMG_0970.jpg
    I think it was $132.00 to have them sleeved in Stainless Steel, they have now been reunited with the backing plates etc, looking pretty smart as well
    http://i659.photobucket.com/albums/u...w/IMG_0971.jpg
    tomorrow after work I will fit up the brake shoes and start the bleed process, I didn't want to get too dirty this afternoon, cheers Dennis
