Hi John,
I tried to follow that instruction sheet before, it is very misleading as the lamp unit must be pulled rearward exactly as it is, without any pivoting sideways.
The vertical front edge of the lamp assembly is held by 2 knob headed plastic dowels which can jamb tightly, if it has not been removed before. As the lamp assembly is smooth there is nothing to get a good grip onto.
A warning, it is possible you may scratch the top surface of your bumper when the lamp assy releases. So clean off the top surface of the bumper and carefully pull the edge of a thin towel well into the gap between the base of the lamp and the bumper, so that the top of the bumper is covered.
If the unit has not been removed before you could attempt spray some water or detergent as a lubricant in the area where the jambed locating dowels are.
Now you need to very carefully pry the front vertical edge of the lamp rearward away from the body. I used a narrow stainless steel paint scraper with rounded off corners, placed between a folded microfibre cloth. I carefully inserted it into the narrow gap so as to not damage the paintwork or the edge of the lamp. Depending on the tightness of the top & bottom dowels, they should release when the lamp is levered back about 5mm.
If you are patient careful you should be able to get this lamp assembly off, if not you could scratch or chip the body paintwork or the lamp.
I lubed my dowels with silicon grease and the removal process is much easier the next time.
Steve
