                                                15th October 2012, 02:15 PM
			Headlight height adjustment/leveling in a 130
					So I was thinking the other day... If you buy a 110 wagon (and some others, I'm sure) you get that dial on the dash to adjust the height of your headlights - absent on a 130 dual cab HCPU.
 So my question is: does
 Anyone know how much of the system is preexisting in a 130? No motors or linkages at the headlights or dials on the dash... But is the wiring there for it?
 Thanks in advance
                                                15th October 2012, 03:47 PM
					I don't know, but just a thought that you could fit air bags to the rear suspension, and then use that to level / adjust your headlights.  If the load is what's shifting your beam, that may be better.
                                                15th October 2012, 06:38 PM
					Michael, indeed I could. But its more just something else to have/play with
                                                15th October 2012, 07:19 PM
                                                #4
					There's a bucket load of empty connectors behind where the switch should be, so... ?
                                                17th October 2012, 11:06 AM
                                                #5
					I was thinking i would like to add this too.. with regards to using airbags to change the angle, i have full airbag suspension and using them to adjust headlight level would not be ideal, infact part of the reason i would like to be able to adjust the headlights is because of the airbags.
