There have been some failures with oyher brands, it is a shell spec ATF and must meet the specs set by ZF. Cheapest in Oz is the get the Lifeguard 6 in bulk direct from ZF.
 Fossicker
						Fossicker
						G'day
I know ATF is an old topic but I'm curious if anyone uses anything other than Lifeguard6 and if so how has your auto box run so far?
Chimpy
 ChatterBox
						ChatterBox
 Fossicker
						Fossicker
						G'day
I got a price of $580 with delivery from ZF in Sydney for 20lt. I've read bad reports about penrite and mixed reports about stuff like duradrive. I find it hard to believe that after 7 years nobody has made a equivalent product for such a popular box
Chimpy
 Swaggie
						Subscriber
						Swaggie
						SubscriberFunnily enough this topic came up yesterday with my son. He has a FPV Typhoon with 308Kw!!! at the rear wheels and on my advice changed the trans fluid.
The mechanic used ZF, and said that he had been told that Castrol are working on it but haven't been able to meet the spec yet.
He also fitted a steel sump from a BMW X5.
Regards Philip A
PS it is FAST.
Yet another case of price gouging in Australia... AU$20.60 per litre in UK, versus what? $43/L from Ford or $bend_over/L from LR!
 Wizard
						Wizard
						Fuchs Titan 4400 is a full synthetic ATF that has been used successfully on the 6HP26. I will be using it on my next flush.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
 ChatterBox
						ChatterBox
						Fuchs does not list this ATF as the same as lifeguard. It is DEXRON III and does not meet the spec. Be very carefull about what you put in the transmission.
It must meet Shell ATF M1375.4 It has to do with conductivity and the matalurgy of the transmission components.
Do not believe what you are told when you are told an ATF is suitable.
DISCO3.CO.UK - View topic - Automatic Transmission Fluid ATF
A few have been told that an ATF is suitable to only find out it wasn't. If it doen't meet the correct spec then you are taking a risk.
What's the ZF approval code for the fluid ?
It'll be TE-ML-xx
