Hello again.
Had a chance to look over the disco and I found the reason the gas usage went up and the diesel usage went down. I had blown the pressure hose that go's from the turbo to the fuel pump to change the diesel rate of feed when you come on boost.
Since there was no more diesel going in to the motor as I revved the engine it was using more gas to compensate for the lack of diesel.
Fixed the line and the problem.
Just wanted to share incase anyone ever has the same problem
Cheers.
