Results 1 to 9 of 9
Thread: how can i get more flex out of my disco??
    Oct 2012
    gold coast
    hi guys just wondering if anyone know any tips or mods to get my disco flexing like a beast ha!
    Melbourne, Australia
    Quote Originally Posted by SeanyG View Post
    what have you done so far?
    Coils or SLS?
    Jul 2007
    Usually longer coils, shocks and a lift, cranked arms, compensate for the angle change on the front diff, double cardan drive shaft. Where does it stop.
    Get some diff locks, then the flex will not be required for traction and you can forgo the stuffing around having to make up for lift induced problems.
    Kingston, Tassie, OZ.
    Like Slug Burner said, get some lockers, then leave the suspension alone. I have gone back to standard length shocks and springs, and installed a rear detroit in the 110. And a winch, too. Rides beautifully, corners beautifully, I don't need to worry about shafts, bushes, caster correction etc etc and it is still a capable offroader.
    JC
    Gold Coast, QLD
    drill out the radius arm bushes
    I rule!!!
    2.4" of Pure FURY!!!
    preston
    Gywn Lewis extended mounts front and rear
    12 inch 7100 billies from the states e shock
    Sus stuff springs 2 inch
    Body lift 2 inch
    Other consumables that break eg break lines, shafts
    But the answer you deserve after that looooooooose question
    I mean d1 d2 d3 d4????
    Fast Dirt, rocks, touring, comp??
    Even preferred tyre size??
    Remove all shocks and one of the four radius arm bolts axle end
    Ramp it and see what's possible
    I would drive very slow though
    Go to 2:20 in the video and you will see the difference between massive flex compared to less flex but a locker. Locker wins.
    [ame=http://www.youtube.com/watch?v=dBNPZFNOK-4]Lockers vs Extreme Suspension - YouTube[/ame]
    preston
    That series had more front flex than the 90
    Classic case of dislocated rear springs carrying virtually no weight
    Therefore getting no traction
    Poorly balanced coil suspension
    I web bet the 90 with rear springs tied in would walk up that hill
    Dc
    Jul 2008
    Ballarat, Victoria
    before you do anything, remove your sway bars!
