Results 1 to 8 of 8
Thread: defender 110 td5 g/box replaced, now hard to start,cranks ova just ages to fire???
    wato64 Guest
    hi a mate recently had a g/box replaced in his defender 110 td5 and it was starting perfectly before fifth gear let go, since having new box fitted has been hard to start?!?! APPARENTLY the cfa has been having the same problem with their defenders taking ages to start (in the western district)??
    any thoughts would be greatly appreciated
    thanks
    wato.
    Melrose SA
    The Crank Position Sensor would have been disturbed with the clutch removal so this could be a good place to start.
    Might be wrong though
    Geelong, VIC
    Is it still cranking as quickly. If not, then possibly the earth lead from chassis to trans isn't quite right (or not fitted at all).
    Steve
    Aussie Expat in NZ
    I'm with SteveG - Another vote for earth strap. You may find that all your earth is going through the handbrake cable..
    Quote Originally Posted by flagg View Post
    Yeah same here earth strap.
    Easy to get one and put straight from the battery to the gearbox as they are next to each other.
    I had the same problem on a 300 tdi
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Mar 2012
    I would have to agree that this is a likely cause and would recomend sort ASAP as the handbrake cables earthing ability is poor and it has a tendency to get to the "on fire" side of hot!
    Geelong, VIC
    Its a quick one to test too. Get a decent jumper lead and connect directly from the battery -ve to the engine or transmission.
    If that fixes the problem its definitely an earth issue.
    Has to be a good jumper lead though with a decent amount of copper in it - using a cheapie wont prove anything.
    Steve
    Aussie Expat in NZ
    Quote Originally Posted by Leyland1980 View Post
    It will smoke heaps before it does catch fire, but is tricky to track down. In other news i have a nice new handbrake cable
