Results 1 to 4 of 4
Thread: Tips and Hints
    Nov 2011
    Murrumba Downs
    Tips and Hints
    Hi all I came across this today. 101 things you didn't know about your Freelander 2
    Hope it helps
    1. Lowered centre bonnet profile reduces reflection glare
    2. angled rise on centre of bonnet reduces rain/water running over bonnet/onto windscreen
    3. Outside Edge of bonnet marks center of tyre track
    4. water jets on Bonnet mark axle centres for easy wheel placement. The rear edge of the back seat aligns the centre of the rear axles
    5. doors cover sills to keep clothes clean when entering/exiting vehicle
    6. Lower window lines provide greater all round vision
    7. Can tow loads heavier than itself
    8. Plastic door detail provides eaily viewable wading depth gauge
    9. brakes are tested in extreme climates such as Death Valley, Scandinavia and the French Alps as well as the "AMS brake fade" test
    10. Alloy wheels are alluminium/silicon compound designed for on and off road strength and x-rayed for microscopic deformities
    11. Exhaust systems are made from Stainless steel
    12. There is a bash plate protecting the engine bay under the vehicle
    13. DSC/CBC is able to select 1 brake at a time, unlike cars without ABS.
    14. Volume control is on the right side of steering wheel - left or right hand operation
    15. Electric Folding wing mirrors reduce drag.
    16. Plugging and unplugging seat belt 9 times turns off audio alert (not dash indicator)
    17. fuel delivered to engine even when car is on a 100% gradient (45 degrees)
    18. Can ride side slopes at 40 degrees (no diff locks means easier to control)
    19. The FL2 Monocoque Chassis is the 3rd strongest in the world ( Freelander 2, Porsche Cayenne, Range Rover (reverse order))
    20. Wheel direction indicator warns against sudden veering when grip is regained (offroad)
    21. HDC means the car will descend a slope at a set rate (adjusted up and down by the cruise controller (are you reading this 4WD pressmen?))
    22. Pressing unlock on key remote for 3seconds unlocks all doors and opens all windows
    23. Pressing lock on key remote for 3seconds locks all doors and closes all windows
    24. Pressing both lock and unlock at once for 3 seconds alternates between opening just the drivers door and all doors on first press
    25. engine bay components are water/splash proofed and fitted with breather tubes where necessary.
    26. Low sheen interior surfacess reduce reflective glare
    27. inverted triangle on rubber seal on bottom of doors marks jacking point locations
    28. Models built after oct 2010 have silver instead of gold on the LR logos
    29. Pressing the "light" button on Key fob turns vehicle into giant torch
    30. Steering wheel has telescopic adjustment (tall people will appreciate this) as well as height adjustment
    31. Drivers Seat has height/tilt adjustment to keep legs at optimum comfort position
    32. second row seats are raised "stadium" style
    33. Anti theft encrypted computer needs key remote in slot before vehicle can be started (Cannot be hot wired)
    34. First compact SUV ever to get 5 star encap rating
    35. Winner of Parkers’ New Car Awards 2011 4×4 category
    36. Winner of BBC Top Gear "SUV of the Year award"
    37. Winner of AutoPacific Vehicle Satisfaction Award
    38. Winner What Diesel Magazine Car of the Year Awards "Best 4x4"
    39. Internal vertical door handles are blocked to prevent looping hand through and breaking wrist/arm in impact scenarios
    40. Visor lights are turned off when the visor is returned to its "up position" (like a fridge)
    41. The larger dash buttons make them easy to use with gloves, on bumpy terrain and at-a-glance
    42. 3 cigarette lighter jacks for chargers etc rated at 180W, One fitted in the loadspace stays live for fridges etc when vehicle is switched off
    43. spare wheel load space cover can be reversed, exposing a hard plastic wipe clean work surface
    44. The vehicle is based on the EUCD platform (European D Class) shared with Ford, Volvo and Range Rover Evoque
    45. Centre coupling is handled by Haldex. The electronic coupling was developed for the Freelander2. 1500nm of torque can be transmitted in 150 milliseconds
    46. Larger horizontal internal door shoulders provide an elbow rest for long journeys
    47. Plastics and polymers used in interior minimise squeak on rough journeys but don't look like Tupperware
    48. Stock, has the same wading depth as a Defender (500mm)
    49. The TD4_e is the first production vehicle to feature "Stop/Start" Technology
    50. Winner of Auto Express "Best Compact SUV" 3 years in a row
    51. Winner of WhatCar? magazine "Best Compact 4x4"
    52. Electronic Brakeforce Distribution (EBD) means brakes are biased depending on speed,terrain and direction (are you reading this 4WD pressmen?)
    53. Winner of Caravan Club "Tow Car of the Year"
    54. "Warranty Direct" statistics most reliable Land Rover (44RI against Disco@190RI, RRS@143RI & RR@293RI)
    55. Also known as "Hippos" after the UK ad campaign
    56. Surround sound system comprises up to 14 speakers
    57. 7 Airbags - including drivers knee bag and the option for deactivating front passenger airbag for child seat
    58. winner of BusinessCar "Best Small 4x4" award
    59. Terrain Response can be altered whilst vehicle is moving.
    60. Winner New Car (Ireland) "Best SUV"
    61. Winner Auto Revue (Austria) "Best SUV"
    62. petrol model is The first compact SUV to feature a transversly mounted straight 6 engine (smooth and safe)
    63. Land Rovers best selling Model
    64. No exposed key locks. The emergency lock is under the dust seal
    65. There are some 25 ECUs on board the vehicle, running at 125K (Medium speed) and 500K (High Speed)
    66. scores 34.84 out of 37 on "how safe is your car"
    67. The body uses double sided zinc coated steel panels - the most sophisticated anti-corrosion treatment ever used on a Land Rover
    68. Battery is charged through a smart charge system (IPSM - intelligent Power System Management). Rather than consuming fuel when accelerating
    69. Inline 6 petrol engine designed to resist dust, mud and water intrusion and operate at extreme angles
    70. Later models feature neutral control logic. A stationary vehicle in Drive has drive load reduced to save fuel
    71. Vehicle tested in temperatures from -40celsius to +50 Celsius, upto 95% humidity and and altitude of 4000m
    72. Start stop equipped vehicles use the technology in temperatures as low as 4Celsius, newer models at 0 celsius
    73. Tyre characteristics including rolling resistance are optimised for the entire range of available tyre sizes on stock vehicles
    75. GRC (Gradient Release Control) releases the brakes gradually up or down slopes in both forward and reverse
    76. Fitted with an "Event Data Recorder" a bit like the black box on an aircraft
    77. The Queen has (at least) one.
    78. The headlight washers will cease working to preserve water for windscreeen when the water level gets low
    79. Land Rover have made military (administrative) 2WDs in the past, long before the public eD4
    80. Used by Police in England, Wales, Luxembourg, Italy amongst others.
    81. Roof load rated up to 75kilograms
    82. Ready to go off road as soon as it leaves the dealers forecourt, no mods required
    83. Spare wheel stored inside vehicle reduces drag
    84. Fail safe computer system will still allow the vehicle to operate up to 50Kmh in the event of a failure
    85. Winner Car Middle East Award "Compact SUV of the Year"
    86. Winner Truck Trend's Compact SUV
    87. Winner ASMW (Association of Scottish Motoring Writers) "SUV of the year"
    88. March 2011 saw the 250,000th Freelander2 cruising out of the Halewood manufacturing plant
    89. Badged as LR2 in the US
    90. 3 recalls, 2 for diesel booster & PTC heater, one for sunroof. All before 2009. one recall for LR2 Airbag in US (2009/2010)
    91. Has an OBD port above the accelerator. Plug in a bluetooth dongle and download an App for your phone and you can monitor performance
    92. 12,000 km service intervals
    93. Models with Bi-Xenon lights have adpative lighting and manual switching for driving overseas (other side of the road)
    94. Double locking disables the doors from inside and out. Even if someone breaks a window and reaches inside, they can't open the doors
    95. Fuel filler spill enclosure and drain to keep fuel off paintwork
    96. Winner Auto Test(Germany) ZF Road Test "Compact SUV"
    97. Winner Fleet News "Best Small SUV"
    98. Full time 4WD (if you don't have the 2WD eD4), no low range. often called a Soft Roader (But manufacturers don't like it)
    99. ENCAP 4 star child protection rating
    100. There is a tow loop under the plastic plate at the front of the vehicle.
    101. Your Freelander2 is amazing, join a 4WD club or attend a Land Rover Experience day then get out there and start exploring. One life, live it.
    Reclined Guest
    Useful post
    Thanks, had my FL2 for five years and didn't know some of this stuff.
    RowdyD Guest
    Very useful!
    Brunkerboy Guest
    Smile
    Just bought a 2012 FL2 last weekend. I am thankful for this forum and that was very reassuring reading the 101 list. Thank you.
