Originally Posted by
Drover
To be honest I don't know how much benifit you would gain by moving the ECU, but I do know it will be a huge task.
I have had mine up the Cape York a couple of months ago and did many water crossings. Nolan's was well over the bonnet as was the ford before Nolan's.
All that I have done as far as improving wading depth goes is
1/ extend the rear diff and fuel tank breathers.
2/ replace factory ducting to the air box with 90mm flexi hose.
3/ Safari snorkel with custom made adaptor to attach directly on to the flexi hose.
Next on the list will be replace air box with custom made unit or work out how to seal the lid properly.
If you get water over the ECU, there will lots of other components that also will be under water long before it. Including the throttle position sensor.
