lucky buggers, good on them.
Came across this exellent blog done by a Victorian couple driving their PUMA 110 from S/Africa up to Europe.
TURKEY | Tincaninafrica
Contrary to what a lot here might think (about taking a PUMA through Africa) they have a very trouble free journey. I'll paste in a paragraph below of all the issues they had with the car (basically the AirCon stopped working and that was it).
Cost them $40,000. Took them about 7 months.
David
• Total kilometres travelled: 30,639
• Total fuel used (litres): 3,304
• Average fuel consumption: 10.8l/100kms
• Average fuel cost: $1.36/litre
We had the following mechanical problems:
• Engine problems: Zero. (Never missed a beat or failed to start once. (Temperature never rose above “normal” once despite 50*C+ road temperatures at times).
• Chassis problems: Zero
• Drive train problems, UV joints etc: Zero
• Wheel bearing failures: Zero
• Shock absorber failures: Zero
• Oil seals blown: Zero
• Bushes failing: Zero
• Rear wheel brake disc protector plates shattering around bolt holes due to constant vibration. 2 (Welded up in Rwanda. Cost $30 (Could have been more serious if had taken out the ABS sensors, but luckily didn’t).
• Air-conditioning failure: 1
(Still doesn’t work. Attempted repair in Nairobi Kenya unsuccessful – lasted 1 day! Cost $130. A real pain especially in Sudan and Egypt, but probably helped us acclimatise to the heat)?
• Electrical problems: Zero (Although we suspect the air-conditioning issue is electrical as it blows fuses)?
• Mirrors shaking loose on mountings: 2
• Doorhandles shaking loose: 2
• Windscreen breakages: 1 (Due to a little s**t in Namibia with a stone in his hand).
• Punctures: 1
The following servicing took place:
• Full 10,000km services & oil change: 2
(Maun Botswana and Nairobi Kenya. Another service now due in UK)
* Oil change (Greece) 1
• Fuel filters: 2
• Air filters: 2
• Differential oil changed at 50,000km in Nairobi (found to look black)? 1
Land Rover fans will be happy to hear that the Toyota Landcruiser of Fabio and Aneke that we travelled with over much of the same distance experienced:
• A complete failure of the intermediate shaft and oil seals between gearbox and transfer case requiring repairs at Toyota in Khartoum.
• Leaking oil seals on transfer case.
• Sheared off rear wheel studs.
• Fuel filter sucking in air causing engine to die intermittently.
• Front shock absorber leakage and failure (Australian Old Man Emu’s they were, which caused some embarrassment)!
• Auxiliary Battery failure.
(But then it must be said that their Toyota had 120,000kms on the clock, our Defender only 50,000).
Jason
2010 130 TDCi
They took the easy route. The left hand side is a LITTLE more tricky !
Also they went in autumn and winter: less rain on the east coast.
But I reckon those were clever choices.
Some mad Hollanders did the same route, but in reverse, in a 1969 VW Kombi last year for the Soccer World Cup..... die kaaskoppe is mal!
I notice that they are wearing general grabbers, or is this another pic ?
Go the mighty PUMA
Observed on a trip a few months ago that almost 1/3rd of the African tour companies are now using Puma's.
Roger
Thats just awesome - go the 'Tin Can' !
jakeslouw:
"They took the easy route. The left hand side is a LITTLE more tricky"
you're picking nits mate! Its a great achievement either route
Alan
Trip of a lifetime!! Bloody good setup and blog as well!
