Results 1 to 4 of 4
Thread: ABS and TC lights TD5
    Mar 2010
    South East Tasmania
    Hey,
    Driving along last night and both the TC and ABS lights came on. Pulled over, switched the ignition off, restarted. Lights back to normal. Happened again this morning. Anyone had anything similar?
    Cheers Bob.
    Jan 2009
    Seymour, Victoria.
    ABS/TC Lights
    Hi. I had similar. I checked codes with a nanocom and found the pump was running permanently. Just needed a new pump relay, which was $80 and all good.
    Good luck.
    Nino
    Melrose SA
    Bob
    Yes at the beginning of a problem run of TC /ABS issues
    Get a Nanocom or equivalent and check what codes are coming up.
    It may be a wheel sensor with crook wiring or too much air gap failing that it could be a Shuttle Valve fault.
    If its a crook sensor buy them from the UK they only cost about 75 Pounds each if its a Shuttle Valve fault beware of option B on a Defender
    It is very easy for the modified wiring to short on the mounting and jam the front brakes on this happened to me and isn't much fun.
    If you cant get a Nanocom or something to check codes, go around with a large screw driver and bump each sensor home with the heel of your hand
    Don't use a hammer you will damage the sensors
    Mar 2010
    South East Tasmania
    Came on again on the way home, checked the relays and one seemed very hot to touch.
    JC has offered to plug me in
    Hope it's just the relay!
