Results 1 to 2 of 2
Thread: Compact battery for a 12' boat. Charging advice required.
    Swansea, NSW
    In my tinny at the moment I've got a normal car battery (about 380cca) to run the navigation and anchor lights plus a small sounder. What I'm looking at doing is replacing the car battery with one or maybe two smaller 12v batteries like these, 7AH 7 AMP HOUR BATTERY AGM SLA UPS ALARM RECHARGABLE 12 VOLT 12V + BONUS | eBay, as they would be a bit more convenient in both size and weight. My question is would it be OK to hook these up to the outboards charging circuit which is rated at 6 amps ?. The motor has no electric start so theres no need for high amperage delivery.
    Thanks,
    Anthony.
    Jul 2007
    Quote Originally Posted by Stuck View Post
    Thanks,
    Anthony.
    It will come down to how long you run your motor for. I think that 6 amp charging current for a 7 amphour battery is a bit high but it will work. I suspect that 6 amp is probably a short circuit current. I think you will be ok, it will come down to how much use vs charge, may have to do the occasional top up on a charger.
