Thread: Pre Summer boat maintence
    Williams West Aust
    I uncovered the boat yesterday to crank it up and start some pre summer maintence.
    Removed the floor,all ok down below,as you would expect on a 2003 boat that has only done 177hours.
    I will be replacing the fuel lines and bilge pump for peace of mind.
    Also hardwiring my second spare battery with a marine 2 way switch too.
    Few other small jobs and she is ready for the Xmas holiday break.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Torres Straits
    andy,
    Source some marine silicon hose for the fuel line.
    Yamaha product is the stuff i have been able to find in cairns
    You will never have to replace it again. Well worth thr price.
    S
    Apr 2007
    NW Tassie
    change your gearbox oil and look for signs of milky oil, if present do the seals in the box. If no leaks remove the leg and put some grease on the top spline where it goes into the engine head/crank. Remove prop and grease the spline.
    blaze
    Apr 2007
    NW Tassie
    forgot, fit new plugs and keep the old ones in the boat for spares, check expiry date on flares, check condition of pull start rope. check life jackets, if self inflating check condition of cycinders
    Then when all that is done andy head north.
    blaze
    Williams West Aust
    Quote Originally Posted by bblaze View Post
    blaze
    Plugs are new at last service(25hrs),bought the flares the day I took you shark spotting,all 4 life jackets are brand new in the packet.
    Will do the oil as its easy,still intend dealer servicing it every 50 hours,cheap insurance
    Would LOVE to drag it to Broome and beyond.6 numbers and Im there with a new tow vehicle
    Andrew
