Originally Posted by
PaulP38a
You are correct to try to keep the closed shock length the same as original. If you increase closed length you will need extended bumps and may actually lose articulation.
Front shocks are near enough to vertical so +50mm on the open length should work ok with Gen III's, but I would suggest a safety margin of 25mm to not max them out.
I think your comment about rear shocks and may be reversed... If we treat the shock as the hypotenuse of the triangle, the air spring as the adjacent and assume that 45deg is the nominal angle, then the open shock length can be about 1.4 times the extended length of the air spring. The calculation in your subsequent post look about right though.
Good luck finding such shocks. Be sure to share with us if you do.
