Results 1 to 8 of 8
Thread: 300TDI not run for six months
    Apr 2010
    Ascot Vale, Melbourne
    Hi Im going to see a 300TDI defender tomorrow that hasnt run for 6 months, as the owner has been away. Its at his sisters property now with a flat battery.
    Anyway the battery is dead so tomrrow Im going up to look at it with a new battery. It seems in pretty good nick so I dont forsee that there will be any problem getting it to run but is there anything I should be looking out for, any common or usual issues that might occur from leaving a tdi sitting any length of time that may prohibit it from starting?
    thanks , Chris
    Check the oil, water and fuel level, throw it in neutral, take a socket and ratchet onto the alternator bolt, bar the engine over a turn or 2 by hand to make sure its not stuck.
    pull the wire off the fuel solenoid and crank it till the oil light goes out put the wire back on then fire it up.
    if it doesnt fire in 5-10 seconds you might need to rebleed the fuel pump but thats about it..
    May 2006
    Woolgoolga
    Didn't start mine for 4 months, started first hit of the key, ran as if I'd only just started it 5 minutes beforehand.
    Apr 2010
    what is the reason for doing this? i understand it will turn the engine over without throwing fuel in but dont see why??
    Australia
    Ensures oil pressure and reduces the wear stress and potential damage after a long absence of oil circulation.
    Apr 2010
    Quote Originally Posted by strangy View Post
    makes sense! thanks
    if the oil pump has lost prime it means the engine cant fire up without oil pressure.
    barring it over by hand first simply makes sure that you dont have anything siezed on the belt end or obstructions within the engine
    Free Again Thanks Dan
    Mine sat for 2 years fired up no probs with a good battery . Then im not one to do things by the books hey jc
