Results 1 to 4 of 4
Thread: Unable to connect Nanocom or RSW unlock suite to EAS
    Jan 2008
    Medowie, Port Stephens and Sydney
    Hey all,
    Not having any luck accessing my EAS to clear a fault. I'm using a Nanocom Evolution and my old faithful RSW Unlock Suite and cable. The fact that both are failing to connect tells me that there's an issue with communication to the OBD port.
    Fix attempts include;
    Swapping EAS computers with a spare
    Replacing under seat small black box (relay?)
    Replacing relay in fuse box
    Swearing in the EAS's general direction
    Googling for similar issues
    No success
    The Nanocom works for all features other than the EAS. When hitting this page it locks up and i have to reset it.
    Any suggestions on next steps would be awesome!
    Thanks,
    Too bad you're not nearby. I have a Testbook T4.
    Check for corrosion in the OBD connector.
    Coogee, South of Fremantle, WA
    I had similar issues, was corrosion on OBD2 connector as suggested previously.
    May 2008
    Agree that it is most likely a dodgy pin or connector on the OBDII port. My Nanocom also does this occasionally, so I jiggle the back of the pins on the OBDII port until it works. Must take it out and clean properly one day.
    On the OBDII, these pins correspond to the DB9:
    Pin 1 = RTS
    Pin 5 = signal ground
    Pin 11 = Rx
    Pin 12 = Tx
