On the passenger side of the thermostat housing are two bosses, which can both be tapped to 1/2"BSP. One of them can be fitted with a 1/2" water tap - the sort which has the wheel on top and is commonly found in hardware stores. See Dennis's post below for where the return pipe goes.
Most installations I have seen use 1/2 copper water pipe, with presumably hose connectors in the pipe somewhere, to allow for engine movement.
You may find it awkward to tap the holes when the thermostat is on the engine; in any case make sure that the housing is in good condition without too much corrosion,
Cheers Charlie
  Reply With Quote Originally Posted by mfc
