Pretty much.
I can measure the hoops I have here if you'd like.
The hoops for the rear canvas over here are higher than normal as they had troop seats in the back
What is the standard height eg is the highest point inline with the roofline or slightly higher?
As I will have to cut my set down. Well have to anyway to fit the roofrack :-)
Pretty much.
I have to re-load the ute in the morning so hopefully I remember to grab the tape and I'll measure from the top of the tray to the peak of the curve. (maximum height)
727mm from the top lip of the tray to the top of the hoop at the centre.
I can get a measurement from the finish of the corner radius to the top of the tray if that helps too, although I'm not sure how I can accurately measure the radius or the distance in from the edge, but I can take a stab if you need it.
cheers that will do it. Thanks for that, much appreciated.
Although the canvas is going to be delivered next year I can cut the hoops down now
