Results 1 to 10 of 24
Thread: WIFI RANGE
    Sussex Inlet. N.S.W.
    WIFI RANGE
    My situation is that my daughter is trying to use her laptop through my wifi setup. However the range is too far for a good signal. It is impossible for her to bring her computer closer and I cannot shift mine or the wifi modem. Is there any way of boosting the signal. She uses a laptop but is in her study.
    Jim VK2MAD
    '17 Isuzu D-Max
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    Mate, sme rules as any other radio transmitter;
    Relocate the antenna to give as close as possible to line-of-sight
    Minimise absorbtion by walls, se above
    Use more power, some (most?) wifi units have variable power output. Note- you may give your neighbours more signal than the other end of your house. PASSWORD!! You should also make it invisible.
    When all else fails, add a repeater. These can be had for ~$100
    Hope this helps.
    Dave.
    WA
    Or the cheap option, drill a few holes and run a cable between the modem and her room.
    Wifi will transmit over the whole house and around the nearby neighbourhood. If you are not picking up the signal there is an issues with either the modem or the WiFi in the computer.
    You should have no issues.
    Feb 2011
    Traveling Aus
    you can get wireless routers with different strengths of wifi output.
    what kind of router do you have and how far are you trying to transmit?
    May 2003
    On The Road
    I would suggest a large tin foil reflector,,
    but you guys would probably laugh
    Jul 2011
    Yarrawonga, Vic
    dont laugh, it works
    get a parabolic dish, a wok will do
    get somone to hold it behind the router so that the signal bounces off it into the direction of the laptop, once you got the best signal then work out a way to set it in that position.
    you could also buy a Linksys WAP repeater / range extender
    That's pretty much what I thought also. We have no trouble around our house using WiFi -all walls are brick (double brick in some cases) and line of sight distances to some rooms would be ~ 20 meters in some cases, plus can see the neighbours networks.
    Interference may be an issue. Is the modem or your daughters laptop located near another device generating RF radiation, ie cordless phone or something like that.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Camp Hill Queensland
    Jaycar have a wifi extender Universal Wi-Fi Extender - Jaycar Electronics
    '95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
    '85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
    '76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
    May 2009
    West Gippsland - Victoria
    Poor wireless signal may be due to signal quality as opposed to strength. Electrical interference is quite common from compact flouros and cheap Chinese LED lighting. Try turning all your lights off and see if this makes a difference. Another cause of poor signal could be interference from a neighbours wireless equipment. Try changing channels in your router and see if this improves things.
    As for tin foil reflectors (as opposed to hats ), I once had a customer who used a pair of USB WiFi adaptors (the ones that look like a large USB stick)mounted in the middle of a wok. Line of sight it worked very effectively over a distance of about 1/2 Km between two PC's.
    As mentioned earlier some wireless routers have variable output. ie. The original Telstra 2-wire brand routers when cranked up from default gave in excess of 10 dB gain, but remember this does not affect the transmit power from the laptop back to the router.
    Deano
