 Originally Posted by
EchiDna
				Does anyone know the part numbers (and/or a reliable source) for the gearbox boots to suit an LT85? not the ones that go on the transmission cover, but the ones directly on the gearbox itself... mine are both split and in need of replacement :-(
thanks in advance!
 The one on the bottom of the gear lever is FRC8271 and the transfer one is FRC6872. Both are referred to as "gromets" . Should be readily available almost anywhere. BMI Sydney is probably a good source.
				Cheers......Brian
1985 110 V8 County
