I have attached a photo of my oil level. How much oil do you think the engine needs. Yes the level was checked the correct way.
Approx. 300ml per notch.
Thanks guys. Next question that was used in 6624klm. Would you consider that excessive?
Mine is there at 3600kms. The D3 soaked oil into the block at first and has not used any since.
Over 40,000ks on the clock and have never needed to add oil between oil changes. Having said that, I change the oil every 13,000ks. Haven't noticed any real drop in oil level at any time since I have had the vehicle.
Looks like I need to get mine checked out.
Any white smoke mowog?
I have travelled over 116,000Klms in my D4 3.0Lt.
The most I have seen it down is 2 notches.
Have been getting an oil & filter change every 13,000Klm's from new.
Cheers, Craig
I was getting the oil done every 6 months and there were no issues. Last 6 month service the oil wasn't changed. As the D4 had only done a few 1000 klm since the last service.
No white smoke that I can see.
