If I had to do the heater core I'd remove the dashThere's a P38 heater core mod referenced in rangerovers.net wherein they use a heater core from an Audi (obviously they're a lot cheaper in the USA! ) usually obtained from a wrecker. The only hiccup is that you need a couple of adaptors because the inlet/outlet spigots on the Audi core are a different size from those on the P38...both cores are manufactured by Valeo.
