Results 1 to 10 of 20
Thread: High Mileage Freelander 2
    Adelaide - Torrens Park
    One of my customers has a Freelander 2 TD4 with nearly 195 000km on it. No major failures in that time.
    I got to thinking after I serviced it last week that it must be up there as being one of the highest mileage Freelander 2s in Australia. How far have yours gone?
    Only 80K for me. 195K sure is a lot but good to hear there's been no major problems. The 240K service looks like a big one, but 240K between major services isn't too bad.
    I think he might trade it in before then. The service I did recently was pretty much a 'B' service. Oil, air, fuel and pollen filters. I also got the trans oil changed (for only the second time).
    What is involved with the 240k service?
    at a guess..
    download the user settings to a memory device. remove the oil and expansion tank caps.
    wheel out the old F2 and wheel in a new one, replace the oil and expansion tank caps then upload the user settings.
    well that's probably what you could easily believe they do if you pay for a dealer to do the service.
    As much as Dave would like to bag the FL2 it's really hard to do. They have been around 6 years now with three recalls and no common major failures at all. In my experience they are fine to service at home too. I still really enjoy driving mine even after 5 years, I can't think of a vehicle in its class to replace it with.
    240K you need to do the timing belt. I think at a LR dealer you'd be looking at over 2K. I also assume you'd need to start looking at suspension components too depending on its life.
    Labour Estimate 5.2 Hours
    Engine Oil - 0W 40 full synthetic Castrol EDGE Capacity 5.9 Litres
    Antifreeze - OAT organic acid treatment
    Automatic Gearbox - Castrol Transmax J Capacity 7.0 Litres Automatic
    Transfercase - Ref to Land Rover Capacity 5.9 Litres
    Rear Axle -80W 90 Castrol EPX Capacity 0.7 Litres
    ADC - Active demand coupling Ref to Land Rover Capacity 0.65 Litres
    LR006295 - Sump plug washer
    LR005816 - Air filter
    LR001313 - Fuel filter
    LR001247 - Engine Oil filter and seal
    LR000996 - Belt
    LR000660 - Idler pulley
    LR000772 - Oil seal filler / drain
    LR001949 - Washer flanged
    LR004257 - Belt
    LR005362 - Tensioner pulley
    LR000901 - Fresh air pollen filter kit (EC)
    This Freelander has now had it's first major failure.
    Yesterday I fitted a second hand turbo after the original stated making whirring / whining noises. Something had failed internally, it was also down in power and throwing fault codes.
    Still not bad going for 199 000km.
    Could it have been the actuator arm?
    The arm is definitely not seized, we could see it moving when giving the engine a rev. I just eyeballed it (sitting on the bench) and I can't see any corrosion. I think it is more likely an internal failure.
    mikehzz Guest
    Mine's on 149766 kms, no dealer services since 36k. Drives great, I still love driving it. An awesome car.
    I opened it up and looked at the variable vanes. No issues there, so I suspect bearing failure.
