Pictures would probably help, but the most likely reason is that one of the two cross pins transmitting torque to the clutch fork shaft is broken at one end* and about to let go, so that the lever moves further than it should - the slave cylinder will automatically adjust for this until the piston comes out!
* if it has been replaced by a soft bolt, this will probably be partly sheared, giving the same effect (don't ask how I know!).  The pin must be hardened, a genuine part is best, although a suitable HT bolt will work in an emergency.
