Results 1 to 10 of 14
Thread: Management of auxiliary fuel tank systems
    So I have been informed that an auxiliary tank system may increase the risk of water accumulating in the diesel fuel particularly when tanks are left part full and fuel sits for some time at times when you are just using the vehicle around town.
    What do people do to manage this? I don't necessarily want to keep tanks full all the time, it is a lot of extra weight.
    I am thinking I will fill the aux tank and then pump it Into into the main tank rather than filling the main tank just to keep the fuel fresh and cycling.
    Should I invest in a water watch system?
    I have also heard that putting half a bottle of metho in he tank ocassionally will help to dissipate the water.
    Jan 2010
    Edmonton Alberta Canada
    methyl hydrate gasoline antifreeze for gasoline tanks
    Here in Canada, we pour small quantities of methyl hydrate, (methanol), into our gasoline fuel tanks at the approach of winter or during the winter months. Small quantities would mean a 150ml bottle to a "tank" of gasoline. By a tank I mean from half to near empty, as in 40 to 80 litres of gasoline - it is not a science. The idea is to soak up any water in the gas tank before it becomes a problem. Ideally the whole process seems like a waste of time and money. You never really want to know that it was needed.
    http://www.for.gov.bc.ca/ftp/tch/ext...reeze_MSDS.pdf
    With auxiliary tanks, say located in the rear of a pickup holding maybe 200 litres, I will pour a gallon of methanol in there - again not a science - you are trying to avoid walking in the winter.
    As for diesel, I do not know what is used as there are more variables. Some additives keeps the bugs from growing to large; others try to keep the diesel flowing in cold weather and then there is just plain water.
    For all that, there seems to be additives that claim to solve all the problems.
    http://www.bp.com/liveassets/bp_inte..._Additives.pdf
    We also have this AdBlue diesel exhaust fluid as well for emission control and that is another variable. That stuff does freeze. Maybe that is why gasoline engines remain popular here.
    It seems lots of the fleet pickup purchases are reverting back to gasoline. The overall economics favor gasoline these days - first cost, maintenance costs, fuel costs and resale all tend to favor gasoline in light trucks.
    East-South-East Girt-By-Sea
    1.20 MB
    Andrew
    AFAIK the extra tanks for the D3/D4/RRS are placed between the filler and the main tank, you fill the additional tank and as fuel is used by the main tank gravity runs fuel from the additional tank into the main tank. (At least that is the situation with tanks fitted by Opposite Lock.)
    It also means that the trip computer stops being accurate and the fuel gauge only reads accurately after the additional tank is empty and the main tank is around half full.
    Diana
    Jul 2009
    Bad diesel fuel is a real problem, we were in picking up our Holden the other day and were speaking to the guy in the service department. Another customer was complaining about is new diesel vehicle running badly out of the blue for no reason.
    The service manager then recanted a story about a 18 month old Hyundai that they had just repaired that had got a bad tank of fuel.
    The repair bill was $19,000, the car had a new RRP of $38,000.
    Chances are around $19,000 was all the Hyundai would have been worth being 18 months old. Lucky or them their insurance paid for it.
    He was saying they often get to do jobs on damaged diesel systems. Out here in the country bad diesel fuel contaminated by water is quite common unfortunately. That is the reason I often have said that I regret not buying the petrol V8 D3, just my luck one day I'll get a really bad tank of fuel and the D3 will grind to an expensive halt.
    Terry
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    NSW SW Slopes
    Some D3/4 aux tanks are the fill point and gravity feed to the main tank but others use a 2nd filler and a transfer pump.
    Ellendale Tasmania.
    We fill both all the time, ours is gravity feed, so no pump, fuel goes through the auxiliary tank to fill the main.
    Baz
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Mine uses a pump to pump the fuel from one to the other manually.
    Gladstone
    When I fill, I fill both. It hurts the wallet but I don't do it that often. I have the LongRanger with the electric pump. The trip computer updates distance to empty after the transfer.
    Dec 2009
    Ranelagh, Tasmania
    Around town driving.
    I run my main tank down to near empty (500km) then pump aux tank into main until it is full on the gauge. At the 1000km mark I pump the remainder of the aux tank into the main, It is obvious when the aux tank is empty as the aux pump gets very noisy. I then fill both tanks at between 1100 and 1200km about $230.
    I have a filter between the aux and main tanks and change this every second service (20K). Last time it had about 5ml of water in it. I change the main fuel filter every second service as well and drain it every service.
    On a trip I do the same except I use the scanguage distance to empty guide me on when I need to fill up.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    1.20 MB
    Quote Originally Posted by Redback View Post
    Baz
    I have been wondering if you put a fuel shut-off solenoid valve between the two tanks and fill with the valve open then shut the valve would it solve the computer errors?
    You then open the solenoid to top up the main.
