how much was it?
Afternoon all,
I have just finished experimenting with my D4 & installed the mood lighting loom into the vehicle.
This illuminates the release handle (green LED) the large pull handle (white LED) & the lower door pocket (white LED).
With the park lights turned on...Taadaa it works! The dimmer switch adjusts the brightness.
The plug is in the loom with a blank on the end. The easiest way to fit is start at the bottom & work upwards as there is also a path to follow for the loom to sit it.
Took 10mins to fit per door card.
Price is approx $55.00 per loom.
Sent from my iPad using Forum Runner
how much was it?
Onya Pete!
Disco ball next![]()
Do the door trims have to come off,i am guessing yes.
Part number of loom would be good.
Thanks in advance![]()
Front door mood light part number is LR021380
Rear door mood light part number is LR021381
