Dynamat works well as a sound deadener to stop vibration noise in panels and also reflects heat. Its not much of a sound barrier on its own.
I don't think having two layers of dynamat on top of each other would be worth the extra cost, if you went for two layers you would need to add something like dynapad as the second layer... if you did go with two layers of dynamat it would be better with one layer on engine bay side.
