Results 1 to 4 of 4
Thread: salisbury seal
    YEPPOON QLD.
    salisbury seal
    Hi , i have just noticed oil weeping down around the rear right disk brake shroud on my 1996 tdi 130 with the salsibury rear axle. Presumably this is from the hub seal ? Can somebody please help me with the part number for the seal ? Should the bearings be changed at the same time the seal is changed ? I
    have had a look online for parts but can't find seals / bearings specifically described for the salsibury axle.
    Bearman's Avatar
    Hay Point
    Quote Originally Posted by JamesB View Post
    G'day James,
    The seal part number is RTC3511. The bearings should be ok but have a look at them when you have the hub off
    Cheers......Brian
    1985 110 V8 County
    Oct 2006
    canberra
    And that seal sits below the edge of the hub by 4 or 5 mil not flush you can use your drive flange to install the seal
    Jul 2012
    ferntree gully australia
    hi jamesB if you are happy that it is your stub axel seal it would be a good idear to check your stub axel as well to see if it is groved because ,if it is it won't work for long.regards jimr1.
