Results 1 to 8 of 8
Thread: different size uni joints
    Oct 2008
    bacchus marsh
    got a 2002 defender 110 td5 went to replace the uni joints
    went to my local bearing place, went through his books and ordered 4 unis all the same size as per all his books
    ..replaced rear uni,s no problem went to do the front guess what different size a lot bigger in the body cap size is the same
    why is it so ????????
    thanks in advance
    NSW far north coast
    Apparently some TD5 Deefers use 1330 uni's on the front shaft, some a 1300 at the t/case and 1330 at the diff end, (or is it the other way around ?) Tdi's use HD 1300 size uni's at all four spots.
    Bear in mind that the 1300 uni's that most books list aren't really up to the job, Land Rover/GKN HD uni's use a trunnion that has the same OD and needle roller length as a 1310 Spicer uni.
    There's a few threads on here that list the difference, the part numbers and photo's of the physical differences.
    [edit]
    Why do Landrover UJ's flog out ??
    HD DC or 1330 uni for front prop ?
    Quote Originally Posted by rick130 View Post
    Apparently some TD5 Deefers use 1310 uni's on the front shaft, some a 1300 at the t/case and 1310 at the diff end,
    Other way around... although some I think may have both. My current front shaft has the larger joints at both ends
    JDNSW's Avatar
    Quote Originally Posted by Psimpson7 View Post
    And it should be pointed out that the shafts are interchangeable between different models, and unless you have owned it from new, you have no way of knowing whether either shaft is the same as the original - for example, my 1986 110 has a TD5 rear shaft.
    [edit]
    And my 92 Tdi has 1300 Uni's and smaller shafts.But my 93 Tdi had 1310 uni's all round and larger shafts.
    So I think it is easier to say,that anything is possible
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    bahahahaha the Landrover parts bin strikes again!
    NSW far north coast
    Quote Originally Posted by LowRanger View Post
    :smack: ( the sound of a hand smacking a forehead....)
    Oct 2008
    bacchus marsh
    the joys of owning a defender
