i went for 2.5" normal bend with no mufflers, cheap as chips........
i believe the turbo spools up quicker but hard to tell what if any increase in power and torque...........without putting your rig on a dyno before and after your exhaust mods i say most guys want to bleieve there is an increase just because they have done the mod. i have had mine dyno'd a couple of times but never before and after each mod
do you monitor EGT's? if you have tweaked the fuel pump i would suggest installing an EGT guage
I should have kept the resinator which sits behind the rear wheel, as i can hear the 'drone' if the rear passanger window is down, more so on freeways when there is concrete barriers beside you. Its not really that bad and i have gotten used to it
					 ). I am also after better low end torque and less turbo lag.
