Results 1 to 10 of 13
Thread: Pushing CT up steep amp in revers
    Jan 2012
    Hello Together,
    I have a fairly short but steep driveway and have to push my CT up there in reverse
    Is that a problem as I assume the revers gear is not design for that?
    Thanks a lot
    Steve
    Disco 3, LLAMS, OL BullBar, Chipped, Transmission Oil Cooler - Great Aussie Camper
    Have something to sell? Check out our custom Shopping Cart Solutions
    http://www.4sprung.com.au
    I don't think it will be a problem, it's not as if you are reversing your campertrailer up Mt Everset...
    I'll leave any "technical" details about reverse gearing to more knowledgeable members on here - but if it were me I wouldn't be worried.
    Brisbane,some of the time.
    If it is steep i would use low range.
    You probably have nothing to worry about.
    Jan 2012
    Thanks gentlemen didn't think I could use LR in revers that's a good tip though will do that as it feels quite heavy going up in normal revers
    May 2011
    Orange Grove WA
    Steve, I reverse two very heavy trailers up into our shed, and always use low for this. I also have to adjust the air suspension to make the rear top of trailer pass under the structural beams.....lift up so that the rear drops a bit, then back down again so that the air con is then not torn off.
    Have been doing low range reverse for 8 years now, 5 in a patrol, 2 in my Touareg, and 1 year with the Disco....I reckon you will be fine.
    Brett....
    Jan 2012
    Thanks Brett will actually try this now, getting CT ready for Holliday on Friday:-)
    Jul 2009
    Just make sure if you have manual over ride brakes on the CT that you put the tab down so the brakes don't come on while reversing making it even harder.
    Speaking from experience here ...
    cheers,
    Terry
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Jan 2012
    Yes making sure of that, also speaking from experience here :-)
    Actually zip tightened it down now
    adelaide
    Do you zip tie it down every time you revers?? Or have you locked it down all the time? so NO brakes when driving.
    Sep 2011
    Minyama
    I often use low range when I need to move the trailer into a tight spot, especially when it's not on even ground. It gives my more fine throttle control as you can't use the brake and accelerator together on the 3.0 D4, the ECU cuts throttle if the brake is applied. One of the joys of drive by wire!
