Results 1 to 2 of 2
Thread: Jeep tear down & rebuild in less than 4 minutes
    Thommo Guest
    Exclamation Jeep tear down & rebuild in less than 4 minutes
    Not sure if any one has seen this one before:
    Rebuild a Jeep under 4 minutes - YouTube
    whilst the vehicle has been suitably prepared (no fluids, prepared nuts & bolts etc) it still does demonstrate the virture of a simple vehicle. I recon the same could be done with a series 2 LR what do you think?
    Jan 2008
    Nowra NSW
    The British got very good at doing a similar thing with the WW2 jeep, assembling one out of a packing case cum trailer.
    The War time jeep had alot more in it than a CJ jeep shown in the vid.
    The jeep shown in the vid uses the engine oil filter housing on the motor as the fuel tank, has no cooling system ( the radiator is for show only)
    Body is just siting on studs as is the motor and transmission.
    The shacket bolts have no nuts on them and most likely sharpened to a point so they side in easy etc
    I wonder if it had brakes ?????.
    The British show team which done similer with a WW2 jeep was still doing it long after the ww2 jeep left service with the British services as the landrover was unsuitable for a quick dock side assemble and drive onto in the never , never of the colonies
