Thread: VW Computers?
    Aug 2009
    Brookfield Melb. Victoria Australia
    VW Computers?
    Hi All
    I might as well start this off, as I think it was my idea!.
    I have heard that a lot of functions on the VW computers can be accessed without diagnostic software, I really want to turn off the Automatic locking, It's driving me nuts.
    I do the repairs & maintenance at the local retirement village when at work never get out of second gear. I might move from one unit to the next a dozen times a day.
    Every time I move the Amarok locks itself, every time I stop it unlocks. The locking mechanism will be worn out before its first service.
    I also want to know how to turn off the service due warning, & is this common with the Golf, Polo, Amarok etc.
    As stated in a previous post I am waiting for a workshop manual from the UK that covers all the late model VW's.
    It looks like you can get a similar, like the Nanocom for the VW's. Anyone know more??
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    i have the equiv for caddy, vagcom i think it is called
    i altefed s besp of stuff in the csddy
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    sheerluck Guest
    It's called VCDS now rather than vag-com, and yes it does exist out there.
    I had the equivalent for my wife's Merc from DealExtreme (DealExtreme - Cool Gadgets at the Right Price - DX Free Shipping Worldwide). Have a hunt on there for VCDS and be pleasantly surprised by the price.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    i use the ross-tech unit as it has some really good info as well as the obd / canbus interface
    Ross-Tech: Home
    Sep 2006
    Northern Beaches
    Vag-com! HAHAHAHAHAHAHAHAHAHA!!! No wonder they changed it.
    Jeff
    Aug 2009
    Quote Originally Posted by incisor View Post
    Ross-Tech: Home
    Looks good will investigate further.
    May 2006
    Woolgoolga
    Andrew, have you had a look on the amarok forum? Lots of good info on there, just need to sort though it. Planning to order our high line in the next couple of weeks
    Manly QLD
    Ross-Tech produces VCDS (Vag Com Diagnostic Software). VAG = VW Audi Group. It is unlocked and will work on any VAG car with CAN.
    VW and all its subsidiaries have the complete OBD2 standard implemented for the entire car, most cheapo OBD2 scanners will be able to read and clear faults from all ECUs. However to change coding strings you will need VCDS. Be warned it is far more comprehensive than any LR system I have seen, including BB, in saying that it is less user friendly and will allow the user to easily ‘brick’ an ECU as it will happily save a coding string that will not allow the ECU to work at all. User beware!
    If you are just after someone to update one or two settings you may find someone to help as you can on here. Pop on over to vwwatercooled.org.au and introduce yourself, there is a VCDS sub forum - we are a helpful bunch sometimes, and several guys down your way are up to coding for a box or similar…
    BTW, the auto locking, and the 2 button press to open all doors was the first things I changed on our VW....
    L322 3.6TDv8 Lux
    St Helena,Melbourne
    1.13 MB
    I have a vag-com usb OBDII cable that i bought in error if any is interested .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2009
    Quote Originally Posted by Vern View Post
    Just replied to your modification post
