26th December 2012, 07:30 PM
fuel leak
Hi guys I have a fuel leak from the quick release fuel connector infront of the fuel reg. Is this a common issue and or how do I seal it. I have replaced the fuel reg in the past and all is good there. Fuel is dripping straight on to the starter. The vehicle is a 2002 Defender TD5.
26th December 2012, 07:42 PM
hmm, not common, but the o rings inside the fitting can be carefully hooked out and replaced. good luck, hope it works out
i have a complete set of fuel lines from a wrecked '02 if this helps ? .
jc
