Hi Graeme,
With the 4x4 intelligence one you fit the steel support bracket to the steel bumper bar after the plastic outer skin has been removed. Then you take accurate measurements from the body to the centre of the pivot axle which has not been fitted yet. Refit the plastic bumper and mark the centre of the hole to drill using the accurate measurements. The pivot axle can then be fitted.
Hopefully the Front Runner one is similar.
D4 2.7litre
