Results 1 to 10 of 15
Thread: 2007 MY D3 specific issues/advantages?
    sheerluck Guest
    I've got the go ahead from the Minister of War and Finance to purchase a D3, and one that has come to my attention is a 2007MY TDV6 in Zermatt Silver.
    The question is, are there any specific issues or advantages of that model year compared to 05/06?
    So far I've found that the EGRectomy is a a little more tricky, and there are a couple of recalls that I need to make sure have been done, swap the auto tranny sump and filter, and buy a Faultmate.
    Any other hints or tricks for a new player?
    07MY is a better vehicle as a lot of the first production vehicles had niggling issues which were all rectified on the release of the 07MY
    Just make sure the VIN has a 7 in it (the 10th digit) otherwise whatever number is there is what MY it is.
    Cherrs
    Dec 2012
    Adelaide, SA
    Yep - ie, the VIN for my 08 RRS is
    SALLSAA138A14xxxx
    The 8 denotes the model year. Look for a 7 or higher.
    07 has a new fuel delivery system with different filter and lines. I belive the pump is revised too.
    sheerluck Guest
    Quote Originally Posted by sniegy View Post
    Cherrs
    Thanks Sneigy, definitely a 07MY with a build date of 9/2006, though the VEDA check shows it as 2006 (I assume it was first rego'd right at the end of 2006).
    Oh well, time to warm up the chequebook!
    sheerluck Guest
    Quote Originally Posted by Rich84 View Post
    ............07 has a new fuel delivery system with different filter and lines. I belive the pump is revised too.
    Thanks Rich. Anything else you're aware of that changed from 05/06 to >07?
    The CANBUS design was changed either 07 or 08? This reduced the chance of relatively benign faults cascading into major faults.
    Gordon
    sheerluck Guest
    Quote Originally Posted by gghaggis View Post
    Gordon
    So this is the good old blown (or cheap) taillight turning the dashboard into a Chrsitmas tree problem solved, or less likely to happen?
    Bangor, NSW
    Pete - in hindsight, that may be the case - but at the time, it sure did feel like LR were doing their best to try and smite me!
    For example:
    1) Numerous failures and recalls for High Pressure Fuel Pump --> fire risk and left stranded.
    2) Oil leaking into brake booster --> possible brake failure.
    3) Clock spring faults --> airbag not deploying in case of accident.
    I would say that now the above have been addressed, the MY07+ are great. But at the time - with months off the road, it was not an enjoyable experience.
    Just glad that the above never resulted in any fatalities.
    Dec 2012
    Adelaide, SA
    Haha Jonesy... sounds more like they were trying to kill you than smite you!!
    Quote Originally Posted by jonesy63 View Post
    For example:
    Hey Jonsey,
    Ahh Hindsight :-)
    I am not going to disagree with these issues, but also not every vehicle displayed these problems that unfortunately you had, I also agree it would of been excruciatingly painful to put up with some of the issues that have been displayed in some of the earlier vehicles too.
    But seeing some of the earlier vehicles D2, D1, P38 etc & their problems, the D3 is brilliant. A huge step up from the earlier vehicles in reliability.
