Results 1 to 6 of 6
Thread: Nissan Cabstar 5 speed
    Kime Guest
    Hi all,
    Am considering the option of a nissan 5 speed box behind my 202. Have found one with a marks adapter already behind a 202.
    My questions i have, for anyone who may be able to help, are what are the gear ratio's, or even better still, what sort of RPM would i be doing in 4th and 5th at relative speeds???
    I'm trying to achieve low 2's rpms at 100klm/hr.
    I currently have 4.7's in the diff's, would these be suitable?? or would i need to still change the diff centre's to 3.54's to achieve these rpms???
    Any help from the guru's would be muchly appreciated
    Joel.
    Sep 2006
    Northern Beaches
    A mate did it years ago and said it was the best mod he did. It was a Series 3 ute with a 186 and he had 4.7 diffs. It had a lower first and a taller top. He towed a car trailer with hot rods etc on it a lot. The only reason I didn't do one was you had to either move the engine forward, or the transfer case back.
    Jeff
    Kime Guest
    Did your mate say what sort of RPM he was doing at 100klm/hr??????
    Sep 2006
    Northern Beaches
    It was nearly twenty years ago, and I am pretty sure he didn't have a tacho.
    Jeff
    Irymple, Victoria, Australia
    Joel,
    considering that a series Land Rover does approx 3000rpm with standard gearing and 7.00 profile tires at 80 kmh and about 3750 at 1000 kmh, the Nissan box in 5th should be approx .75 - 1 which would make the engine rpm at 100 in the viscinity of 2750.
    This is only an estimate as I am not sure of the exact ratio of fifth gear in the cabstar box.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Melrose SA
    Use this and google it will answer all your questions
    Ashcroft Transmissions - Ratio Calculator
    CABSTAR. Type, 5-Speed Manual. Gear Ratios 1st, 4.225. Gear Ratios 2nd, 2.341. Gear Ratios 3rd, 1.458. Gear Ratios 4th, 1.000. Gear Ratios 5th, 0.796
