just finished fitting these to my freebie today not a hard task just fiddley but kept me ammused for a few hours the next bit is to find either a numberplate plinth or a frame nudge bar failing that i need to do some sculpting to fill in the hole on the side.
hardest part for me was remake the +ve and -ve connections no a very hard task at all so now tonight quick drive to try them out will post a pick when i get around to taking one
also on a side note just fitted a set ofthese bridgestone duelers 697 after a blowout on a dirt road going into a sharp right hand down hill corner and nearly going down the side of a mountian ended up on the other side of the road in a culvert only dammage was popped the headlight out of its lower mounting bracket and bumper on passengers side was missalinged
the worst dammage is to the underside or the car front passangers door skirting is all bent up but will streighten it out sometime (looks like a fair bit of work) main thing is im still alive but i thikn its also testomony to the engineering that went into thes little suvs
